ZDRAVÍM VŠECHNY. PROSÍM VÁS NEVÍM SI RADY. V LEDNU JSEM KOUPIL VS 1400 R.V. 1997 NAJETO 47000. DNES JSEM POPRVÉ POŘÁDNĚ VYJEL A STALO SE MI CCA PO 7 KM ŽE NĚKDE Z PŘEDNÍ ČÁSTI MOTORU TO ASI 5 KRÁT STŘELILO TAKOVÍ ZVUJ JAKO BY POPLAŠÁKEM. CELOU DOMU SE MI ZDÁLO ŽE MOTORKA NECHCE TÁHNOUT ALE PO TÉ PŘÍHODĚ TO JELO UŽ JAK MÁ, JENŽE OD TÉ DOBY MÁ MOTORKA O DOST VYŠŠÍ VOLNOBĚH NEVÍTE ČÍM TO MUŽE BÝT RESPEKTIVE CO STÍM. MOTORKA MÁ LADĚNÉ VÝFUKY STAŽENÉ NA JEDNU STRANU. PAK JEŠTĚ JEDNA VĚC PŘESTAL FUNGOVAT PŘEPÍNAČ DÁLKOVÝCH SVĚTEL A CHCÍPÁK TO STÍM ALE NEMÁ NIC SPOLEČNÉHO TO JSEM ZJISTIL ASI PŘED TŘEMI DNY....ŽÁROVKA JE VPOŘÁDKU KDYŽ BILKNU JEN TÍM BLIKACÍM CAPLÍKEM TAK NORMÁL FUNGUJE. VŠEM MOC DÍK ZA KAŽDOU RADU
VS 1400 | 3295 | martinVS | 02.04.2011 19:59 |
Re: VS 1400 | 1298 | Laďa VS | 02.04.2011 20:46 |
Re: VS 1400 | 1070 | martinVS | 02.04.2011 21:10 |
Re: VS 1400 | 1051 | danykopy | 04.04.2011 09:10 |
Re: VS 1400 | 914 | martinVS | 04.04.2011 20:27 |
Re: VS 1400 | 1109 | Medved | 11.04.2011 16:19 |
Re: VS 1400 | 967 | Helena | 15.04.2011 10:33 |
Re: VS 1400 | 860 | Medved | 29.04.2011 13:16 |
Re: VS 1400 | 753 | Polis | 09.05.2011 23:35 |
Re: VS 1400 | 718 | Medved | 10.05.2011 09:13 |
Re: VS 1400 | 747 | Vladimír | 10.05.2011 09:23 |
Re: VS 1400 | 601 | Medved | 13.05.2011 20:02 |
Re: VS 1400 | 766 | Polis | 10.05.2011 19:18 |
Re: VS 1400 | 648 | Vladimír | 12.05.2011 13:14 |
Re: VS 1400 | 606 | Medved | 13.05.2011 20:03 |
Re: VS 1400 | 779 | Vladimír | 15.05.2011 00:17 |
